Martin roboscan pro 518 mode 3 fixture Topic is solved
Lithium
Post by Lithium »
Hello,
I was looking for the Martin roboscan pro 518 mode 3 fixture.
I did a search whit google but can not find anything to download.
Does someone has the fixture and want to share it whit me?
Hope you can help me.
Re: Martin roboscan pro 518 mode 3 fixture
Post by LJ_krede.dk »
the most common way is that if some fs users have the fixture you are looking for they have uploadet it in FreeStyler Fixture Files - User created Downloads
since that isnt the case i think you have to make the fixture by yourself. its aslo easier for you to make it than others who hasnt the lamp to test it on.
if you need help just post the question in this forum together with the fixture-file. then people are happy to help
Lithium
Post by Lithium »
Thanks for you replay.
I already used the search button in that sub forum.
Nothing that can help me.
When i made the fixture i will upload it for people who want to use it.
If there is someone who has one, please post it, it will help me but many other people.
Lithium wrote:I was looking for the Martin roboscan pro 518 mode 3 fixture.
did you make an overall search on this website? i did a quick search and find out that f-design.ch may be able to help you: look at problem with Martin Roboscan Pro 518
looks like he has a fixture file for the 518 pro. maybe he has sorted the problems out and you esealy can adapt hes fixture to a mode 3
Lithium
Post by Lithium »
I will try to contact him.
The biggest problem whit this fixture in mode 3 is the gobo channel, it has some gobo's but also the gobo rotation in it.
The second one is the color chanel.
hmmm,,, dont you have the 518 pro allready in your fixture folder???? I have
but here it is... i think it is the mode 3, but i am not sure
Roboscan Pro518.pff
(164.06 KiB) Downloaded 98 times
Lithium
Post by Lithium »
Yeah that's him, needed to change pan and tilt.
This is the one i was looking for!
