Color not responding to sound with the fixture i created
silver
Post by silver »
I have a colorsplash junior and a optima RGB LED PAR64 that I created a fixture file for myself.
In sound to light, the colorsplash jr reacts to light while my fixture file doesn't. I compared both. The channels are laid out differently but I don't see why the colorsplash works while the Optima doesn't. I attached the fxt file. Maybe the error would be obvious to someone else. I'm new to freestyler.
Manual is here for Optima:
https://www.ledlighting1.com/files/PDFs ... Manual.pdf
EDIT** changed my file to the pff format.
Re: Color not responding to sound with the fixture i created
silver wrote: EDIT** changed my file to the pff format.
Good man gotta go out tho so carnt help sorry
FreeStyler Version: N/A
Post by remco_k »
Does the optima respond normally when controlling the faders on the right in FreeStyler?
silver
Post by silver »
Yes the responds normally when I adjust faders. I think maybe just has to do with my definitions. One thing I was thinking was the names of cotnrols? Is that relevant?
FreeStyler Version: 3.3.7
Post by LJ_krede.dk »
just playin around with your fixture,, I have the same problem as you... i will get back if i find something out in the next couple of hours
/LJ_krede.dk
Aalborg, Denmark
Weird. :?
have tried a couple of LED par fixtures and the oly one which working with the sound to light was the colorsplash junior, and that was only the blue channel. :o
Is it only me who have this problem? :shock:
/LJ_krede.dk
Aalborg, Denmark
silver
Post by silver »
YEs I get the same behavior. Sound 2 Light just makes some fixtures flash blue. I really would like to just adjust intensity with sound2 light. Then set different colors on some lights and have them flash with music. I still cannot get Optima64 to respond to sound.
