"Magic 3d Easy View" button Topic is solved
Huxie
Post by Huxie »
Hey Guys, i got some trouble.
When i've add'ed my fixes, the Magic 3d easy view button doesn't appear, what can be wrong?
I can't really descripe it better ..
Re: "Magic 3d Easy View" button
Post by LJ_krede.dk »
i can't seem to reproduce your issue. can you try to give a bit more information of what you do in steps?
example:
1) I select Setup --> add/remove fixture
2) i add two Mac 250 Entour
3) and so on
maybe then we can find the reason(s) of your problems
Huxie
Post by Huxie »
Hey Krede
I add'ed two Martin Mac 250 Entour, pressed okay, and now, the button still doesnt appear.
I can't really give you further information, all i know is, that the button just aint there.
Seems like your Danish too, but we're suposed to keep the language english.
If you want, you can add me at messenger;
Admin@huxie.dk
Huxie
Post by Huxie »
I solved the problem by fixing FS setup from "No interface" to "Virtual Interface" .
Thnx guys ..
Onge wrote: Silly question maybe :- You did take the option to install the Sunlite Magic 3D Easy View when you installed FreeStyler ?
arg, why didnt i think of that first :? if the 3d icon isn't there/gray scaled, the 3d isn't installed, of course .
i have been chatting with Huxie via messenger and the first problem was that he didn't install the 3D Easy View as Onge predicted
The second problem was that Huxie had selected "no Interface"
but now it should be up running. Sometimes its easier to describe and solve the problems on your native language than English :lol:
