I could use the profiles for these fixtures.
EFX-500
http://www.martin.com/service/downloadf ... pdf&cat=65
Chauvet RGB Technostrobe
http://www.chauvetlighting.com/system/p ... RGB_UG.pdf
Thanks in advance!
Chris
Profiles for EFX-500 and Chauvet RGB Technostrobe Topic is solved
matt
- Admin
- FreeStyler Version: NULL
Re: Profiles for EFX-500 and Chauvet RGB Technostrobe
Here is the File for the RGB TechnoStrobe
ST-4000RGB.pff- (3.53 KiB) Downloaded 82 times
Matt Hankosky
flickr.com/photos/mattxhank
matt
- Admin
did it work ok?
Matt Hankosky
romch
I actually haven't had a chance to play with it yet. I'm still learning how to use the software. But these are the two fixtures I have that were not a part of the given profiles. I noticed on the old forum someone had asked for the EFX-500 profile. Is that one still around somewhere or could I get that one too. I'm hoping to spend some time with it after my gigs this weekend. Thanks again!
Chris
Chris
romch
Alright, I've had a little time to play with this. I can't get the technostrobes to appear in light jockey. I'm not sure if they are supposed to or not, but I can't seem to get them to pull up in the offline visualizer. Any ideas?
