Profile needed:Chauvet Intimidator spot 680
fcprod1
FreeStyler Version: 3.0.1
Post by fcprod1 »
can anyone help me out on this one?
FreeStyler Version: N/A
Re: Profile needed:Chauvet Intimidator spot 680
Post by remco_k »
fcprod1 wrote:can anyone help me out on this one?
With that? Hanging it up in the rig?
Connecting the DMX line? Addressing it? Cleaning it?
You can assume that if anybody had created the fixture file for this, you'll be finding it in the "FreeStyler Fixture Files - User created Downloads" section.
Read the forum rules in read, at the top of your screen. Then try again.
I'll give you a hint: find the DMX definitions and start the fixture creator.
If you ask again: post the DMX definitions here, as well as the fixture file you have created so far.
If you are ready making this fixture file then post it in the "FreeStyler Fixture Files - User created Downloads" and you'll be the hero for the next guy looking for this.
