I'm playing with freestyle while I am waiting for my interface to arrive.
I have 4 Chauvet Clolrstrips and 4 Chauvet LED Rain 56 fixtures.
When I view my program with Easy View I can see the LED Rain 56 fixtures react and change color. However the colorstrips do nothing at all in Easy View. Does anyone know how to get Easy View to show me the Colostrips in action?
Max
Colorstrips not working with Easy View? Topic is solved
aquas
Re: Colorstrips not working with Easy View?
hi,
i use Eurolite Par64 RGB and Led Bar 648, and the color in freestyler is a little diferent that the Par create...but is simple i watch my lights to see what i want. About easyview, to generate a Bar in easyview i put 4 or more Par64 side by side. somewhere in the forum has a topic talking about this.
maxnew40
OK, it turns out there is also a fixture called color strip RGB mode and although it doesn't show any beams at least the fixtures turn colors. This works good enough for now.
Max
Max
