no more export in fixture-creator Topic is solved
ziggy2
Post by ziggy2 »
hello
one day the "export" feature in fixture creator stopped to work.... I don't know why
for shure, I tried to remove and reinstall the whole thing (recently I updated for Freestyler 3)
but nothing changed...
I can import fixtures (for example those which I created last year with the export feature); but no way to use the export-feature now any more...
nothing happens when click on the link or use the shortcut-key...
any issue ?? any sugestion ??
Re: no more export in fixture-creator
are you using windows vista??
ziggy2
Post by ziggy2 »
...no; I'm on Windows XP
I really carnt see why its not working...
