I apologise if this is because I'm doing something obviously wrong, but I've searched the help and the forum and haven't managed to find an answer.
If I try to create a sequence for my RGB LED PAR's (or any fixture in offline mode), when I've finished the sequence of steps and look at it again, all of my steps have been changed to something bizarre!
For example :-
I create step 1 of a sequence as all of my cans set to full red and full intensity and all active channels (RGB and Intensity) set to Fade
I add a new step and change all of my cans set to full green, full intensity and all active channels to Fade
I add a new step and change all of my cans to full blue, full intensity and all active channels to Fade
I then save the sequence.
The result of this (as far as I would expect) would be a fading sequence going from red, through green, to blue, with the ability to loop and fade back to red.
Yet when I look at the sequence now, all three steps are now set to full blue, full intensity and all active channels Fade
I've created other sequences (doing exactly the same steps as above) and ended up with everything green, or sometimes all white!
Is this just a nasty bug or am I doing something ridiculously stoopid
Andy
