Greetings all,
I, like many am new to this. I'm using Enntec's OpenDMX on a thinkpad T42, running the latest version of Freestyler. I've noticed a few things that I can't figure out how I'm fouling things up.
My general workflow is, create sequences, add to que, test, and revise. I am care full about exiting the que prior to editing any sequences. Every now and then however, when making changes to or even adding a sequence, all my changes indicate an over-ride and nothing is modified in the sequence. The sequence editor is not in offline mode. The only thing that seems to cure it is closing and re-starting free-styler. What would cause this?
The other thing that has happened, is in the middle of all this, freestyler I seem to have somehow changed where freestyler looks for all of my sequences. When I go to open a sequence, the dialog box is empty. However when browse to the chases folder, they are all still there.
Any help is appriciated greatly
Thank You
-Ryan
A Couple Questions about creating sequences
merccat
- FreeStyler Version: 3.0.1
Using Freestyler 3.0.1 on a IBM T42 Thinkpad running Windows XP Pro. Interface Device: Enntec's OpenDMX. Not using a visualizer.
- remco_k
- FreeStyler Version: N/A
Re: A Couple Questions about creating sequences
I had this issue to only I did'nt need to restart FS, just reopening the sequence editor while the cue screen is closed was enough.merccat wrote: My general workflow is, create sequences, add to que, test, and revise. I am care full about exiting the que prior to editing any sequences. Every now and then however, when making changes to or even adding a sequence, all my changes indicate an over-ride and nothing is modified in the sequence. The sequence editor is not in offline mode. The only thing that seems to cure it is closing and re-starting free-styler. What would cause this?
In the next version of FS this problem is solved, and better yet, while sequences are running from the cue, you actually can create a new sequence or edit an existing one.
Since I'm not the developer I don't know when this next version to be released, but I guess it will come pretty soon.
Raph is working out some other issues I and other users have brought in, so we'll have to wait for that.
merccat
I can't wait to try it!
