new sequence Topic is solved
djmaxx
new sequence
Post by djmaxx »
Hello! Are effects (swirl, etc) of (pan, tilt) shape can be generated in sequence. Like FX sinus,saw,....?
FreeStyler Version: N/A
Re: new sequence
Post by remco_k »
Did you even try? :(
Anyway, the answer is yes.
djmaxx
Re: new sequence
Post by djmaxx »
Yes, I try Freestyler over one week, but can't generate. Please write what i need to do.
Re: new sequence
Post by remco_k »
Can't do anything with this information.
What and how are you trying? Describe the exact steps what you do and what is not working for you.
djmaxx
Re: new sequence
Post by djmaxx »
I'm insert 4x moving heads, group them, open all menu's for them and new sequence. Then open gobo, color, lamp, etc.. Press shape and circle, but i can't see generate button for circle? In sequence are button FX and button generate, but its only for sinus, saw, etc..
Re: new sequence
Post by remco_k »
What about pressing the on/off butten above the Shape button...
And more worse; its all there in the manual.
djmaxx
Re: new sequence
Post by djmaxx »
I press on/off, nothing changes
Re: new sequence
Post by remco_k »
I read you post, there's zero information in it so nothing changes here either...
You need to supply way more info than the zero info you supply now. I'm not God, you know...
I also can't smell what you see and do exactly... So, provide all possible information. Does the fixtures react to pan/tilt anyway?
Re: new sequence
Post by LJ_krede.dk »
you can't see in freestyler when you are running a shape in the pan/tilt window, try use Easy3dview or connect your fixtures to freestyler by an interface
1) open the create sequence window and pan/tilt window
2) Press the OFF button in pan/tilt window so it change to ON
3) press the add scene button in the sequence window
4) Press the ON button n Pan/tilt window so it change to OFF
5 save the scene and try to run it.
now you should see that shapes are saved in the sequence: when running the sequence the fixture will start and stop running the desired shape
djmaxx
Re: new sequence
Post by djmaxx »
I open the create sequence window and pan/tilt window, Press the OFF button in pan/tilt window. Then i press the add scene button in the sequence window (it shows step 2\2), and when press the ON button in Pan/tilt window nothing chnges. In sequence it shows step 2\2. When move ball in pan/tilt window with mouse in 3d view lights moves. When i press shape button and OFF in pan/tilt window in 3d view it works. Only in in pan/tilt window ball stays in one point and not move.
scottparkin69
Re: new sequence
Post by scottparkin69 »
i think know what your trying to do
you are wanting it to genarate the shape into a set of sequnces like on high end lighting boards i don't think it can be done yet but i could be wrong
Re: new sequence
....and it is not a bug that the ball is not moving... the ball moving in pan/tilt is disabled... cant remember why.
djmaxx
Re: new sequence
Post by djmaxx »
Okay, this i to want know. Thanks wor helping.
Re: new sequence
LJ_krede.dk wrote:....and it is not a bug that the ball is not moving... the ball moving in pan/tilt is disabled... cant remember why.
I'm sorry but Remco_K did you not spot this within the first few posts?? or anyone else lol
It could of been answered in by his second post basically the ball isnt moving he thought something was wrong when there wasnt the feature of the moving ball isnt a feature anymore lol! its static! but the sequence plays out! Jeese lmao
Re: new sequence
Post by remco_k »
So with this 2 completely useless posts, you would have had the right answer?
djmaxx wrote:Hello! Are effects (swirl, etc) of (pan, tilt) shape can be generated in sequence. Like FX sinus,saw,....?
djmaxx wrote:Yes, I try Freestyler over one week, but can't generate. Please write what i need to do.
Thats awesome! You are the next world wide best mind reader! :mrgreen:
Hell, even with the 3rd post the solution is far far away:
djmaxx wrote:I'm insert 4x moving heads, group them, open all menu's for them and new sequence. Then open gobo, color, lamp, etc.. Press shape and circle, but i can't see generate button for circle? In sequence are button FX and button generate, but its only for sinus, saw, etc..
Even when knowing now that its about the ball in the pan/tilt window, this is still a post without any good info what is going wrong or whats not working.
And lol or not, djmaxx was giving just about none information. If he did that better, I'd anser the ball-not-moving-part-thing in my first post in this topic. Should have saved many people a lot of time. :mrgreen:
Re: new sequence
Lets just put it this way -> Im the admin Im the boss Im the best any problems and your banned lol! :lol: :ugeek:
Re: new sequence
Post by remco_k »
Ah okay,
Here a new ruleset for this forum.
1. User DJ Support is always right.
2. If he is'nt, please read rule 1 again.
A third rule should'nt be needed then. :mrgreen:
Edit:
Here's a nice twist, since I'm a moderator on this forum, I could have banned you to. :mrgreen:
I just did'nt have the guts to do so. ;)
Re: new sequence
as far as Im aware you puny moderators carnt ban us super admins! :lol: :P
Re: new sequence
Post by remco_k »
DJ Support wrote:as far as Im aware you puny moderators carnt ban us super admins! :lol: :P
Should I try? :D
Re: new sequence
try then catch the first bus outta here!!! lol :lol:
aquas
Re: new sequence
Post by aquas »
I see, the ppl likes emotion... i think the boy still don´t understand why the ball don't move... i think is because the referee don't beep to start the game, is like a football game!!!!
cumpr
