help please with sound reaction of scenes.... Topic is solved
raffosdj
Post by raffosdj »
i created sequences, and i put them in the cue switcher, how can i do to play scenes reacting to the sound??? i switched the button react to sound, but it doest work how can i do???? thanks a lot
FreeStyler Version: N/A
Re: help please with sound reaction of scenes....
Post by remco_k »
Onge wrote:
raffosdj wrote:i created sequences, and i put them in the cue switcher, how can i do to play scenes reacting to the sound??? i switched the button react to sound, but it doest work how can i do???? thanks a lot
Read the help pages in FreeStyler.
And then just do what is tells you to do. You'll see, easy. ;)
ayoungman
Post by ayoungman »
When you added your fixtures into your setup you need to make sure the box "make fixture react to sound " is ticked.
This is on the DMX address box. Also, when you run the chase, press the speaker button on the top of your screen and press START. This you use to set the level off the sound to light. HTH
