bug in geni oby-3 = showtec hurricane 250 Topic is solved
THW Mark
Post by THW Mark »
i noticed a small "bug" in the geni oby-3 (which is actually the same as the showtec hurricane 250)
when using the 3d visualiser (and dmx output on the showtec) i noticed the gobo/gobo-rotation channels are swapped. so, adjusting the rotation gave me another type of gobo, and clicking on a gobo just rotated it.
I don't have a geni oby-3 zo i can't test whether the bug is in the freestyler fixture file or the easy view file. but here is a fix that works with the showtec hurricane 250 and the oby-3 in easyview...
OBY-3.zip
small fix on gobo/rotation channels
(536 Bytes) Downloaded 83 times
FreeStyler Version: N/A
Re: bug in geni oby-3 = showtec hurricane 250
Post by remco_k »
I googled the manual: http://www.landergruppen.dk/SITE/Produc ... _OBY_3.pdf
Channel 4 - Rotating gobo wheel
Channel 5 - indexing & Rotating gobo rotation
In the fixture delivered with FreeStyler those 2 are swapped, Gobo rotation is at channel 4, the gobo selection is at 5.
So you're right. Thats a bug in de fixture file.
THW Mark
Post by THW Mark »
lol, even that manual is the same as the showtec version, except for the logo :mrgreen:
so, swap the channels for the next release ;)
THW Mark
Post by THW Mark »
woops! found another bug. The gobo number 6 starts at 120, in the current file at 114 or something. update...
OBY-3.zip
another update
(537 Bytes) Downloaded 83 times
Post by remco_k »
Onge wrote: ....
I have come across many manuals from Chinese manufactured fixtures, badged and sold by other companies where the manual is so wrong.
That problem is not only with Chinese el-cheapo fixtures. I've had seen these kind of errors also with the better brands.
So Onge has a point. Maybe the manual is wrong. But still, then there is something wrong in easyview.
Either way, only someone that has this fixture can check this. For the moment, I think its good to see the manual as the 'truth'.
THW Mark
Post by THW Mark »
i'll test it on the showtec soonish. i'm 99,9% confident that they are indeed the same.
