Hirestimer.ocx
StefanB
FreeStyler Version: 3
Hirestimer.ocx
Post by StefanB »
2 weeks ago i made a clean installation with windows.
Next week i have to use FreeStyler again, so i wanted to install it right now, but:
Installation went fine, no probs. But when i try to start the program, i get the error:
Runtime error 339:
Component 'hirestimer.ocx' or one of its dependencies not correctly registred: a file is missing or invalid.
I've already did some homework on the internet, but i did not found something that helped me.
I have the file hirestimer.ocx on my computer.
What is the problem here, and how can i fix this?
StefanB
Re: Hirestimer.ocx
Post by StefanB »
When i do that, i get an error to, from that program.
That is that C:\Program can't be loaded.
StefanB
Re: Hirestimer.ocx
Post by StefanB »
by run in windows,
but i don't know how, but it works:p
Thnx 4 the help!
Re: Hirestimer.ocx
if on windows xp go to run type cmd then where the flashing dash is type that above and hit enter or in vista type in the search bar cmd when it shows in the listing right click it and seect run as administrator once loaded do as above ^
Re: Hirestimer.ocx
if above doesnt work try typing cd \ first in the cmd program then hit enter now try doing what it says above ^
XSD&C
FreeStyler Version: ?
Re: Hirestimer.ocx
Post by XSD&C »
Ok. So please explane step by step how your problem was solved... Im having the exact same problem and can not get the program to work.
