First have you tried? Log in to Search the Forum for help! Learn more about using FreeStyler at the FreeStyler WIKI HERE
Showtec Pixeltrack pro - 20 channel mode (5x2 sections)
(8.97 KiB) Downloaded 42 times
Developer of the Sound 2 Light application (SL.exe) for FreeStyler: https://www.digiplay.nl/fs Electronics runs on magic smoke. If it escapes, the electronics won't work anymore!
Yeah, that would be fine.
Also the limit of maximum channels per fixture is an pain in the ass, what is it, 33 or so?
The showtec pixeltrack pro also has modes above 20 channels. Up to 160...
Those modes are kind of unusable in FreeStyler, except when you just put 8 of those 20 channel fixtures 'behind eachother' with properly incremented DMX addresses.
Doing that will work, but obviously is an ugly workaround because when you have 2 of these fixtures in 160 channel mode, then you have to put 16 pixeltrack pro's in FreeStyler...
Not to speak if you have 3...
