Hello,
I'm new in DMX programmation but I was able to set new fixture for scans and change colors, but after many tests using others fixtures as model, I cannot find the right settings for my laser which is a DUNE Triple A (http://www.dune-sono.com/Manuel-70169-A5.pdf). There are only 3 channels, see page 13 for DMX protocol.
My concern is that I didn't find which field has to be used to set the channels 1 and 2 for the rotation (speed and clockwise or anticlockwise).
Is somebody can help me ?
Thanks a lot.
How to control the rotation for my laser Topic is solved
sadiv
Re: How to control the rotation for my laser
Thanks Onge.
Unfortunatelly it doesn't work, but it is not due to your fixture but simply because the manual forgets to talk about the channel 4 which controls the rotation
Below is the fixture I did. Tell me your opinion.
Thanks for your help.
Triple A.pff- (45.33 KiB) Downloaded 52 times
