I created the fixture files myself. You really should try to build your own fixture files. You learn from it. It is good to understand how to use the fixture creator. A file someone else built may not have all the features the light has to offer. Also, if a light bulb comes on in your head on how to make the fixture file better, you will know exactly how to get in there and make it the way you want it. We all have different ideas, so if you think of something that would enhance the fixture file, give it a go yourself first, then ask for help when you get stumped. I promise, it will only help you get better grips around dmx software.
If you update the fixture file with something new that you thought of, you should share the updated file with others as well. We are all came to this forum to learn from each other. So share what you learn or create with others.
I posted the Vue 2 and Vue 3 fixture files I created here:
http://www.freestylersupport.com/fsforu ... m.php?f=23
ENJOY!
