Hi there,
Sorry this might sound really thick and a dum question to most of you! I cant seem to get my Magic 3d easy view working. Its says that there no USB DMX interface connected, But there is.
I am using the Enttec pro. Doses Magic 3d easy view work with this hardware?
Also just to let you kno Im a beginner in all this lighting game so go easy on me. I am following the tutorials on freestyler on youtude posted by DJ MM, Cheers MM!!!
Jake
Magic 3d easy view Not working Topic is solved
- djSupport
Re: Magic 3d easy view Not working
how have you loaded 3d view?? you shoud load it by clicking the 3d icon in FS and not the program icon in the FS Group folder
firstblackboy
This is totally a beginner question, but do i have to have a DMX controller plugged in to us the Magic 3D? i was just playing around with FS and don't have my DMX contoller yet and i cannot get the magic 3D icon on the tool bar to be available. it is grayed out. I down loaded the magic 3D and installed it but i can't get it to open either. any help is appreicated. I am a total newbie. Thanks
The easy viewer has to be in same directory as Freestyler.. I will recommend to reinstall Freestyler and remember to set a check mark that you want easy viewer installed as well. then it should workfirstblackboy wrote:This is totally a beginner question, but do i have to have a DMX controller plugged in to us the Magic 3D? i was just playing around with FS and don't have my DMX contoller yet and i cannot get the magic 3D icon on the tool bar to be available. it is grayed out. I down loaded the magic 3D and installed it but i can't get it to open either. any help is appreicated. I am a total newbie. Thanks
firstblackboy
Thanks for the help that did it. Now i just have to learn to use it, but getting it installed is step one.
Thanks again,
Erick
Thanks again,
Erick
