So I'm now setting up the new version 3.0.1. I have used up 20 sequences in a cue but now need more.
I've tried setting up the cuelist so I can add more cues, however when I select the cue from the cuelist all the sequences in that cue are played at once, which means I need to push the cuelist button twice which in turn cancels the sequences of that cue which is being played.
Is there a way to prevent all the sequences of a cue being played when the cuelist button is pressed or is there a way to add more sequences onto a cue ie from 20 to 40
Cheers
									Need more cues, 20 ain't enough!?
				Tee1234
 - FreeStyler Version: 2.96j
- Mattotone
 - Android Dev (Moderator)
 - FreeStyler Version: BETA
Re: Need more cues, 20 ain't enough!?
Try using the fast cue switcher at the top of the  cue list.
Click the cog at the top and save cue.
				Tee1234
Yes this seems to work better, however this way doesn't work with midi whereas the buttons do, any other ideas. ??
