A button in the CUE-Window which turns of the Tap-Sync function for single sequences, similar like the "React to Sound" button.
Why?
I want to make a CUE with two sequences, one for the fixture movement and one for the shutter.
Now the movement sequence should run at the programmed speed, while the shutter sequence should react to the Tap-Sync speed.
This would be a mighty function, so please consider it for the next update!
