Fixtures i need for my freestyler 3 Topic is solved
AllStarEvents
Post by AllStarEvents »
Is it possible for someone to make these fixtures for me:
Acme Spot knight x2
Martin scx 500 scanners x4
Acme Dynatwins x3
Acme Miracled x2
PM me if you need to
Onge
Re: Fixtures i need for my freestyler 3
Post by Onge »
Hi AllStarEvents,
The Martin Mania SCX500 fixtures are already in Freestyler.
Links to the manuals for the others would be a good start to help others help you.
Have you had a go at trying to make your own fixtures ? It can seem daunting at first but the more you use the FixtureCreator the easier it gets and the more you will understand. I myself have now been using FreeStyler for just over a week, fair enough not live yet, still working through what everything does and I have created fixtures for fixtures that are not included in FreeStyler. When I know they are working properly and have got all that is needed for them I will post into the forum. Sorry none are the fixtures you require.
AllStarEvents
I have tryed making my own fixtures but i gave up cus couldnt do it.
here are the manuels for the fixtures:
Couldnt find the manuel for acme miracled so here are the details:
Features:
DMX Channels: 7
Master/Slave Built-in programmes
Controller: Any universal DMX-512 or CA-8 Controller
LED's: R: 80, G: 60, B: 48, W: 36 (244)
Sound Activated
DMX Linkable or Stand Alone Modes
Connections: 3-pin XLR Input/Output
Specifications:
Power Supply: AC240V ~ 50Hz
Power Consumption: 20W
Dimensions: 473 x 279 x 103mm
Weight: 4.72Kgs
Other Manuels attached
thanks
dynatwin.pdf
(3.18 KiB) Downloaded 62 times
knightspot.pdf
(600.81 KiB) Downloaded 103 times
AllStarEvents
manuel for acme miracled now:
Miracled.pdf
(1.34 MiB) Downloaded 66 times
Onge
Post by Onge »
Hi AllStarEvents,
Yeah the MiracLED is a right pain in the a**e as it basically has four gobo channels (Patterns) if using the 7 channel mode.
I have knocked up a quick couple of fixtures for the MiracLED in 4 channel and 7 channel Mode.
They are untested.
In the 7 channel mode the 4th Pattern channel (5) is done by the colour wheel as it only allows 3 Gobo wheels.
The Macros are over channel 1 (mode) and selects the 3 mode types.
You need to add icons for all the patterns that have not been done yet. I.e. Pattern 13 to 26.
And any other things that you might need to do.
I hope it helps and it is a start.
MiracLED 4Channel.pff
ACME MiracLED 4 Channel Mode
(32.81 KiB) Downloaded 79 times
MiracLED 7Channel.pff
ACME MiracLED 7 Channel Mode
(81.86 KiB) Downloaded 84 times
AllStarEvents
Hey,
thanks for that m8.
i will have a go at loading them.
thanks
tom
I suggest you open them up in freestyler fixture creator and LEARN how they came about....
