Prolight LEDJ RGB 252 Topic is solved
enemypoet
Post by enemypoet »
If anyone can build a fixture for this I would really appreciate it if not could somebody point me to a similar existing fixture that I can modify, i've included a link to the manual below, i'm fairly new to freestyler so any help would be very welcome.
PDF Manual
http://prolight.co.uk/images/media/11/1 ... ebcbcae44c
Re: Prolight LEDJ RGB 252
too easy mate Select other fixture fill out manufacturer etc then add a picture if you can put total channels : 4 then select enable cmy/rgb then select rgb values put in 1 in for red 2 for green and 3 for blue put in intensity channel 4 and min 0 max 189 then in strobe put 4 off 189 low 194 med 220 high 250
there ya go a child could of done that!!! did u look at the manual first?? I know your new but jeese lol...
Onge
Post by Onge »
enemypoet wrote:If anyone can build a fixture for this I would really appreciate it if not could somebody point me to a similar existing fixture that I can modify, i've included a link to the manual below, i'm fairly new to freestyler so any help would be very welcome.
Find attached fixture for the LEDJ RGB 252 I have created.
Not tested on real fixture but seems to work in Freestyler OK.
RGB 252.pff
LEDJ RGB 252
(1.78 KiB) Downloaded 82 times
enemypoet
Post by enemypoet »
cheers for the help, very easy when explained just wasn't 100% about some things, anyway much appreciated :D
Onge
Post by Onge »
enemypoet wrote:cheers for the help, very easy when explained just wasn't 100% about some things, anyway much appreciated :D
No problem, hope I have got it right, might need a tweak or two, I have only just started to use Freestyler as well, so it's new to me as well.
