Eligible Sound to Light Channels
The Listener
Post by The Listener »
I know that Sound to Light is not fully developed, but I sure would like more options to include channels labeled other than Gobo, Color, Tilt, and Pan. How about Red, Green, and Blue? Am I missing something? How can I bludgeon a simple 3 channel RGB device into working with Sound to Light?
Thanks,
The Listener
Android Dev (Moderator)
FreeStyler Version: BETA
Re: Eligible Sound to Light Channels
Post by Mattotone »
RGB/CMY is allready supported. However the fixture does require a dimmer channel to operate correctly.
You can fake a dimmer hannel in the fixture creator so that the software will accept it but will not function correctly
djgir
Post by djgir »
Use the light in DMX400, it has fade there aswell as sound function.
Return to “Ideas and Remarks”
