Hi There,
I have some problems using freestyler and freestyler Fixture creator
I have the following problems
In Freestyler, I want to add a Space Color Laser from JB System ( got 2 of them ) I select one, assign a port, select to '' react on sound when able'' and then save my project. Then I go to the ''Sound 2 Light'' and select my soundcard, set it up and then the problem starts. When I test the Laser, I can see the stepper motors inside the laser, moving on th beats of sound, but there's no light. I thought it might be the ''Cue'' because I dont have a clue how that works, so I basically just do ''something'' but rather like to skip it totaly. When I view the '' show output '' everything seems to work, accept that there is no light comming out of my machine. but when i look at the Fixture in freestyler there's a colored block that changes color on the beats of the music.
Now I noticed when I opend the Space Color Laser fixture file in the ''Fixture creator'' that the file was corrupt. I get an error that a file is missing and I cant read the settings used for that laser. So I guess that this would be the problem, I try'd reinstalling Freestyler but no difference the problem persists. I guess I would need to replaye the Fixture file but, can't find it anywhere.
I have been thinking about creating a new Fixturefile for the Space Color and 2 other lasers I have, but I have totaly no clue on how to this. I still have to learn so much about Freestyler. I viewd some Youtube movies about Freestyler but that doesent help a bit.
Can anyone help me in creating a new fixture file for the Space Color Laser or explain to me what i might be doing wrong?
Kindes Regards STG24T
DMX Machine is partialy Working Topic is solved
Sander1986
- Just started using FS
Re: DMX Machine is partialy Working
I have the same problem. I'm Going to try to make a new fixture. if it's done i will upload het here.
grtz
grtz
Sander1986
I have tried to adjust the existing fixture from de JB system color laser but it doesn't work.
can somebody help me out?
by the color wheel or gobo wheel. do you need to take the first value or a random between the first and the last value?
I will upload this fixture and the Space Color Laser manual.
I realy hope someone can help me.
greetings
Sander
greetings
Sander
JBSystems Space Color Laser.pdf- (1.48 MiB) Downloaded 38 times
space color laser.pff- (108.1 KiB) Downloaded 26 times
