Enttec Open locking up fix.
vinnygogo
- Mattotone
- Android Dev (Moderator)
- FreeStyler Version: BETA
Re: Enttec Open locking up fix.
other side please
vinnygogo
hello
i have decided to buy a pro dmx interface. a friend of mine with a lot of electronic skills also wasn't able to find the components. and it is also not sure that after the modification it wil work properly, so i am going to buy a pro. thanks for the help so far!
k__x
- FreeStyler Version: 3.3.4
Im with the same problem, i test it in the day without the sound on and it runs everything ok, but at night with all the sound power turned on, the freestyler stops working every 1 minute with the Enttec open DMX !!!!
the powered hub can resolve it?
or this solution:?
http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... 079wt_1165
thanks
or this solution:?
thanks
jpk
Best fix is simply not using DMX devices that don't have an internal microprocessor. We designed a USB DMX unit smaller than the enttec open but fully compatible with the enttec pro so you get the best of both worlds. Any product that requires attention with a soldering iron should be avoided IMO.
MusicSync
I recommend below ArtNet to DMX interface to replace the USB to DMX device.
http://hz.aliexpress.com/store/product/ ... 20451.html
