STUD LED
mattjake4
Re: STUD LED
Post by mattjake4 »
Hi. Well I see. How would you know if i had run multiple cues at once? Like if i hit play and then hit play on the cue below it, it stops that cue and plays the one I clicked?
Mavi
LJ
FreeStyler Version: 3.2.8
Re: STUD LED
Post by Mavi »
If the checkbox in FS Setup -> Preferences -> Extra Options -> Cue Multiselect alsways enabled is checked you are able to hit GO on the first sequence and then start the next on by hitting GO for the second one and so on. If the sequences affect the same DMX channels always the last started will override the running ones.
mattjake4
Re: STUD LED
Post by mattjake4 »
Okay with continuous testing i cant seem to get it to work.
First off, when i write a sequence with scrolling colors and then i click the stop button and then click on my next sequence, heres what happens:
It basically does the movement i programmed although i have it set to a open spot with no colors, but it follows the que before and does the colors even though i have it set to spot.
Same thing with the strobe que, i click the next one and then it continues to strobe in a cue where no strobing is set.
ANy help?
FreeStyler Version: 3.3.7
Re: STUD LED
Post by LJ_krede.dk »
create a backup file of your setup and email it to me (i have sent you a pm with my address). write which sequences you have issues with and I will have a look. its easier for me to see by myself.
/LJ_krede.dk
Aalborg, Denmark
