being a newbie
Onge
Re: being a newbie
Post by Onge »
Hmm, very strange.
In the lastest version of DVC2 beta I have, there is a new program in the install directory and it is called ScanLib.exe, I thought is was just another part of the existing ScanLibrary program, but I tried to run it on it's own and it starts the "New" not released ScanLibrary Version 2 program and in that there is a Gobo Editor.
As said the images are 120x120 pixels.
You can create your own from scratch :)
You can import picture into it :)
You can save them out as .evg files :)
If you get the beta from the Daslight website you need to change the name of the install file from DVC2_beta.exe to DVC2_setup.exe that is how good they are !!!!!!!
If you do install it when you are saving the gobos remember to point to the FreeStyler\Scanlibrary\Icon folder.
I don't like mentioning that comapny anymore, but people might not know who I am talking about.
I am trying not to saying anything bad about Sunlite as they supply the Magic 3D Easy View program for us to use but is the sister company to the other one.
Hope that helps,
Shannon D
Re: being a newbie
Post by Shannon D »
Just did a quick search and found this thread on creating custom gobos in ScanLibrary:
http://www.nicolaudie.com/forum_support ... f=8&t=2453
Did we hijack again :lol:
Re: being a newbie
Post by LJ_krede.dk »
Shannon D wrote:Did we hijack again :lol:
Yes you did, but it is for a good cause :D
I knew i have seen something about this in an old topic, so did a liitle search:
Putt new gobos into 3D Easyview?
I haven't tried it so don't know if it's working
Shannon D
Re: being a newbie
Post by Shannon D »
I tried that way back when and it didn't quite work for me. Mattone stated that it didn't totally work for him as well.
As stated in this thread: http://www.nicolaudie.com/forum_support ... f=8&t=2453
I downloaded the ESA PRO from here: http://www.nicolaudie.com/download.php and installed. I went in the ESAPRO folder and opened scanlib.exe (the new Scan Library Editor). The new editor has way more features to edit fixture files for 3D. You will probably have to save them in the old format (.ssl). I haven't tried to fix my fixture files for 3D, but will when I get more time. I looks like they have been working on making it better.
I also made a copy of the scanlib.exe and pasted it in the FS folder. The ESAPRO folder can be dumped afterwards.
The online manual for the new editor can be found here:
http://www.dmxsoft.com/manuals/index.php?affman=323
Re: being a newbie
[Edit] wrong link
Shannon D
Re: being a newbie
Post by Shannon D »
LJ_krede.dk wrote:
Shannon D wrote: The online manual for the new editor can be found here:
don't work. try this instead: http://www.dmxsoft.com/manuals_ftp/manual_esa_pdf.pdf
This link http://www.dmxsoft.com/manuals/index.php?affman=323 takes me straight there. Not sure why it doesn't work for you. It should take you here:
The pdf manual you posted is not the same manual for the new Scan Library Editor. The attached pdf is for esa, but has nothing about the new scan library editor. I
dmxlighting
FreeStyler Version: beta
Re: being a newbie
Post by dmxlighting »
Its amazing how this thread has ended up helping evrybody!
Well done guys
Onge
Re: being a newbie
Post by Onge »
I fail on your link as well Shannon D.
I think it might not allow direct linking and what you are getting is your cached copy as now I have visted the page proper I can use the link you supplied.
Re: being a newbie
Onge wrote:I fail on your link as well Shannon D.
I found the page by using the menus on sunlites website. when I click on the link now it works!!! if i remove my cookies it doesn't
fcprod1
Re: being a newbie
Post by fcprod1 »
remco_k wrote:
fcprod1 wrote:Yes i can open up the Magic 3d viewer and i can add the fixtures to it . Dont see any numbers moving but they say that they are on in freestyler. Cant seem to make the lights come on in magic 3d
And you did selected the "virtual interface" in FS?
is that under the set up screen? I only have the option under Interface for controller and not virtual interface or am i looking in the wrong spot.
Shannon D
Re: being a newbie
Post by Shannon D »
Yes, under setup, then controller and off to the right should be a drop down box. Virtual Interface is the last one. Don't forget to click SAVE.
fcprod1
Re: being a newbie
Post by fcprod1 »
ahhhh i got it thanks guys! It works! I appreciate it!
Onge
Re: being a newbie
Post by Onge »
I have added some more info and screen shots to the "Adding objects to your stage" section of the Using Magic 3D Easy View tutorial in the FreeStyler Wiki.
Select the FreeStyler Wiki Home which is towards the top left of this page, blwoe the banner, and then select the Using Magic 3D Easy View link.
More to come as I get the time, please be patient.
Onge
Re: being a newbie
Post by Onge »
I have now completed the Magic 3D Easy View tutorial, well I hope so. It does not go through every feature of MEV but is a good grounding and should enable you to figure out more, but if you get stuck then please ask and I will try to help as best as I can.
It can be found here.
Comments, questions, suggestions to improve it are more than welcome.
Shannon D
Re: being a newbie
Post by Shannon D »
Your an Animal Andre :lol: Awesome Job! I know that took some time to put together. Recognition well deserved for your efforts to the wiki.
Onge Rocks!!!!
Onge
Re: being a newbie
Post by Onge »
Shannon D wrote:Your an Animal Andre :lol: Awesome Job! I know that took some time to put together. Recognition well deserved for your efforts to the wiki.
Onge Rocks!!!!
Why thank you kind sir.
As said any questions about Magic 3D Easy View then let me know.
