GO Monkey - Theater / Band Cue Stack
Discuss Go Monkey here!
Android Dev (Moderator)
FreeStyler Version: BETA
Re: GO Monkey - Theater / Band Cue Stack
Post by Mattotone »
lindsayward wrote:Also, do you think it would be possible for this program to be able to work with cuelists rather than just chases?
I have cuelists on cuelist buttons with several chases in each. To use GO Monkey, I have to recreate these in each cue. It would be nice if each cue in GM could be a cuelist in FreeStyler...
Iv decided for the time being not to add this feature, i don't think it would add much considering the time taken to implement it.
Also considering how GM is used each cuelist would need require manual adjustments, to add loops, wait times and halt on play options.
lindsayward
FreeStyler Version: 3.5.5
I Use FreeStyler for: Church
Post by lindsayward »
Thanks for the response, and for considering this. I also appreciate the reply about MIDI. I'll try some different things, but it's good to know how it is supposed to work so I don't try typing in the box anymore. Perhaps on a future revision you could make the MIDI input boxes not editable...
Thank you.
edoerfel
Post by edoerfel »
I am willing to pay for a timeline in go monkey. If you can add a timeline to go monkey so we can program scenes to a click track and song I will pay hundreds for that feature! Or even a whole aerostats plugin for FS!
edoerfel
Post by edoerfel »
Is there a way to use the cue list in freestyler like gomonkey? When I try to use the cue list in FS it plays all my sequences at once, I only want at a time.
Post by Mattotone »
No, Thats why goMonkey exists ;)
k__x
FreeStyler Version: 3.3.4
Post by k__x »
hi!
do you have a manual? thanks!!!!!!
k__x
Post by k__x »
How can i make it AUTO start like cue in freestyler?
i want to make it start at a programed hour, its possible?
thanks!!!!!!!!!!!!
CaptainBetty
I Use FreeStyler for: Band
Twitter: http://twitter.com/captainbetty
Post by CaptainBetty »
I'd really like a user guide or a wiki or some type of documentation on how to use this. I know there's a video but there's no narration.
The modal windows are prohibitive when working with Freestyler or other windows.
I'm sure this is cool and would probably enhance what I'm doing already with freestyler, but I'd sure like to understand how to use it.
thanks!
While there may be no manual download it and have a play thats generally how I learn! and when it breaks I know never to do that again!
Nathanrs93
FreeStyler Version: None
Post by Nathanrs93 »
djSupport wrote:While there may be no manual download it and have a play thats generally how I learn! and when it breaks I know never to do that again!
Story of my life :lol:
edoerfel
Post by edoerfel »
Hi, when I use gomonkey it messes with my haze machine. It doesn't let it continuously haze while I'm running through shows. Any thoughts?
Post by Mattotone »
Little more detail required.
How are you controlling the haze machine?
do the sequences work out of goMonkey?
Check the out put screen, is it as you expect?
GoMonkey simply pases sequences names to FS, so is unable to "mess" with anything, check sequences for rogue channel values.
deepee11
FreeStyler Version: 3.4.4
Post by deepee11 »
As a theatre and AV tek who's struggled with Freestyler's lack of real theatre stack support, may I thank you for creating such a functional piece of software! I have only found it recently, but it has seriously changed how I can use FS in my day-to-day operations. Cheers!
My main usage of FS/GM is via show control software called SCS. it can send midi out, and here is where i ran into some challenges with GM:
when GM looks for midi notes, it expects them from a 'real' source. in this way, if i click in the 'learn' box for the 'go' command, then click in my show control software (to lanch the midi send cue), the click away from GM is registered, and i can no longer input into the learn box!
I solved this by placing my midi cues to be learned on a timer in SCS , so they happen automatically, and i don't need to leave the GM window. It is however a little cumbersome, but it works so no big deal! (it took me a few hours of head scratching to figure this out, believe me!)
also,now that my control systems are working well with GM/FS, I am finding the need for a 'Back to Top' function in GM more and more. using midi to go 'back' flicks through each cue live, so a function to go to the top of the cue list would eliminate any odd little lx changes.
would it be possible to integrate a 'back to top' functions?
thanks in advance,
DP
Post by Mattotone »
try this, Untested as don't have an active midi or Fs setup to play with.
As far as midi,i think you can type the midi values, the on focus was the easiest way for me to implement midi it can be changed if its a problem.
deepee11
Post by deepee11 »
Fabulous!
Thanks so much for the development Mattotone. It works very well. Apologies for the delay in testing - i got knocked out by a virus over the weekend and am just coming round!
re: midi 'on focus': There's no major need to change it - the way GM accepts midi is fine. I simply thought it would be worth highlighting the method to the community :-)
Thanks again,
dp
edoerfel
Post by edoerfel »
I have my haze setup through freestyler as a haze controlled by the haze button in freestyler. So it has nothing to do with the sequences. I manually turn the haze on in freestyler then go to GM and start the show and it will work for a few seconds and once I start going through cues it starts to stop and start and becomes dis functional. I can't see why it would do this. Anyone else have problems with haze/fog while using GoMonkey?
Post by Mattotone »
Theres still a strong possability that there are sequences which are overriding the haze channel.
Start the hazer,
run go monkey making note of which sequences are running when your haze stops.
repeat again to check for consistency.
check affected sequences step by step to ensure the haze channels are set as off.
also pelase upload your FS backup and GoMoneky xml files for testing.
hovisp
Post by hovisp »
Hi
I'm trying to order my setlist once I've created the XML cues but it only loads them in alphabetical order. Is there a way to reorder the list in go monkey without having to resort to renaming the xml files with a number prefix each time I want to change the running order.
I'd really appreciate any help
edoerfel
Re: GO Monkey - multiple scenes at once
Post by edoerfel »
Hey. How do I cue up 2 difference scenes at the same time in gomonkey?
Example:
Pars changing colors in one scene + And backlights going crazy in another scene = both playing at same time in gomonkey.
Any help? Thanks
Post by Mattotone »
When creating a show , In the editor the left hand list is a scene in the show i.e the list that you will "Go" through. The list on the right is the sequences that play per scene.
So add both sequences in the same scene and they will both play.
edoerfel
Post by edoerfel »
Hi, I've tried that and what happens is the sequence on the bottom plays and loops fine and the one on the top plays the first "step" of the sequence and pauses- it does not loop even if I select loop. I cannot get it to work. Hmm...
Post by Mattotone »
Post screen shots from the edit window please
edoerfel
Post by edoerfel »
Does anyone in here know how I could trigger my midi controller in Ableton Live or Reaper so I can program gomonkey scenes to songs with click tracks via ableton live?
help is appreciated! :)
edoerfel
Post by edoerfel »
hi, i am trying to make an automated show with gomonkey by triggerring gomonkey by midi notes through a DAW. im using Reaper. gomonkey needs an option to type in the midi notes bevause i cant get it to work. watch this video and youll understand.
https://www.youtube.com/watch?v=s7Va9t3 ... tu.be&hd=1
Post by Mattotone »
Read page 17 as a post explains a way round this. A new improved go monkey is in the works.
Return to “GO Monkey - Theater / Band Cue Stack”
