Random DMX values setup.
Dropdown menu
Each fixture separately: Each individual fixture gets random values different from the others.
By fixture group: Every fixture in a group gets the same values, the groups get different values.
Blackout when no beat is detected:
With this option enabled the fixture chosen to react to sound will blackout when no beat is detected in a configurable time.
Start seq. if no sound is detected:
If this option is enabled then the sequence restarts when no beat is detected in a configurable time.
Time combo box:
Time to wait after last beat before blackout or sequence restart.
Pan ch:
Configure which range of DMX values the pan channels get. this way you can avoid the fixture to point at undesirable places.
Tilt ch:
Configure which range of DMX values the tilt channels get. this way you can avoid the fixture to point at undesirable places.
Pan / Tilt Fade:
With this option enabled the pan/tilt channel fades between the values.
Pan / Tilt Fade scrollbar:
Set the desired fade timer by the scrollbar.
Finally you need to enable the “React to sound” on each fixture where you want use this function by right click on the fixture.
