sound_to_light_cue_window_configuration
Sound2Ligth configure the cue window.
In this example we have two sequences.
Color_1 which is a sequence with 5 scenes / steps and sound control is enabled seen by the speaker symbol in the option part of the line.
The other sequence is twist which is a movement sequence created with the Bezier shape tool. The Bezier shape movement is can not be sound controlled and therefor are the sound option disabled.
sound_to_light_cue_window_configuration.1653382815.txt.gz · Last modified: by Jan_K
