If you have FreeStyler already installed, skip to the Magic 3D Easy View installation.
** Free Styler Installation**
  1. Download and install FreeStyler from http://users.telenet.be/freestylerdmx/
  2. IMPORTANT: By default, FreeStyler installs into the C: drive's root directory “C:\\FreeStyler”. Instead, install into “C:\Program Files (x86)\FreeStyler” folder. This is the “proper” installation folder for programs.
  3. Windows Firewall will pop up during the initial install, I allowed all 3 options which may not be necessary.
  4. During the install, select the checkbox to download and install Magic 3D Easy View. It is really just a “download” option. You will manually install Magic 3D Easy View AFTER FreeStyler is installed. If you missed selecting the checkbox, all is not lost! Go to Nicolaudie and download the latest version.
  5. Complete the installation of FreeStyler
Magic 3d Easy View Installation
  1. IMPORTANT: Install Magic 3D Easy View into the SAME folder as where FreeStyler was installed in. The default location for FreeStyler is “C:\\FreeStyler”. If you followed this guide for installing both FreeStyler and Magic 3D Easy View then use C:\Program Files (x86)\FreeStyler.
  2. - Windows Firewall will pop up during the initial install, I allowed all 3 options which may not be necessary.
  3. Complete the installation
  4. During Magic 3D Easy View installation, it will install the SIUDI Drivers into the C:\SiudiDriver root directory. These are used if you have a Sunlite USB to DMX controller device. Sunlite is the company who created Magic 3D Easy View.
Testing
You will open Magic 3D Easy View from within FreeStyler. This allows FreeStyler to control Magic 3D Easy View.
magic_3d_easy_view/installation.1495730318.txt.gz · Last modified: by blanchae
