Installation
- Download and install FreeStyler from http://users.telenet.be/freestylerdmx/
- IMPORTANT: By default, FreeStyler installs into the root directory of C:\. Install into “C:\Program Files (x86)” folder. That is the proper installation folder.
- Windows Firewall will pop up during the initial install, I allowed all 3 options which may not be necessary.
- During the install, select the checkbox to download and install Magic 3D Easy View. You will only install Magic 3D Easy View AFTER FreeStyler is installed. If you missed selecting the checkbox, all is not lost! Go to Nicolaudie and download the latest version.
- Install Magic 3D Easy Viewer
Done
magic_3d_easy_view/installation.1495729499.txt.gz · Last modified: by blanchae
