fixture_control:slider_menu
Panel Description - Slider menu.
Using the sliders in the right side of the FreeStyler gives the possibility to control the DMX values direct.
It also gives the possibility to set some channel related parameters direct by making a “right mouse click” on the wanted fader.
With the right click this menu will appear.
Inverse channel, Disable Channel, Remove channel from playback, Set as lowest limit, Set as highest limit and Remove limits are the same functions as found under the output menu. See
Save as favorite.
This is a way to give a fixture a value that can be recalled again and again. See Favorite toggle
Save as startup.
See Topic not made yet
fixture_control/slider_menu.1334125554.txt.gz · Last modified: (external edit)
