Panel Description - Fog / Smoke Panel
The Fog / Smoke control panel is direct related to the fog fixtures.
This means that the fog machine are to be created as fog machine in the predefined setup at fixture creator.
Fixture Creator - Fog Configuration
The “Fog” button activate the fog as long as it is hold pressed.
The orange LED in front of the button indicates when the fog is on.
If defined in the fixture there are two control faders for fog intensity level and one for the fan speed.
Additional a timer function is available.
When the “Timer” button is activated, it operates where the fog is turned on with the interval (here 40 sec.) and it will be on in the duration time (here 5 sec.)
This is a function FreeStyler generate and therefore nothing the fog machine needs to support.
The small status bar bellow the interval fader shows the actual time. When full the fog is activated.
When the Timer function is on the blue LED in front of the button will blink. When the interval time has elapsed and the fog turns on the orange fog LED will be on.
With the “Continuous operation” check box it is possible to change the operation of the Fog button so when it is pressed fog is on and continuing being on until it is pressed again.
In continuous operation mode the timer function is disabled.
