Captions
This function is used to configure the text / caption on buttons which has a file attached to it's function
The picture shows the Group buttons with file names as caption
Disable buttontext
No text are shown on the buttons.
Replace file names with numbers
This function replace filenames with numbers on buttons.
It is normally checked on but when it is checked off then the buttons will get the names of the files attached to the buttons.
It is the same names as displayed on the same functions in the FreeStyler window.
The buttons affected are:
- Cuelists
- Cuelist tabs
- Groups
- Overridebuttons
- Override tabs
- Sequences
Use custom captions
If a button text has been entered by the user then this text will be used.
