external_control:remote_control_wifi:touchosc
Google Play
Apple IOS
In addition to the apps on your mobile device you need a midi bridge and a Layout editor. These can be downloaded from the download page on the website of the developer.
Installation
As this manual is a work in progress please check later or feel free to help me out.
external_control/remote_control_wifi/touchosc.1539686643.txt.gz · Last modified: by DreNL
