external_control:remote_control_wifi:touchosc
TouchOSC is a tol which runs on Both Android and Apple IOS. You can download the versions following the appropriate link below.
Google Play
Apple IOS
In addition to the apps on your mobile device you need a midi bridge and a Layout editor. These can be downloaded from the download page on the website of the developer.
Installation
As this manual is a work in progress please check later or feel free to help me out.
external_control/remote_control_wifi/touchosc.1539686628.txt.gz · Last modified: by DreNL
