Midi Interface
What is MIDI
As the name implies “Musical Instrument” was created for and originally used for playing music.
However, it is often used in other ways, including controlling other interfaces attached to a computer - such as DMX lighting.
Due to this, some terms that are used do not correspond perfectly between music MIDI and MIDI when used with DMX.
Below will help clarify some terms that are related to music and how they can be compared a bit with DMX:
| DMX Protocol | Max Value | Midi Protocol | Max value |
| Universe | 1 | channel | 16 |
| Channel | 512 | Note | 127 + 0 |
| Value | 255 + 0 | Velocity | 127 + 0 |
Note and Channel in DMX are alike though in DMX 512 are available, while in midi only 128 (127 + 0) are available.
Midi Controller
As MIDI controllers go, anything that can generate a midi signal can be used. Controllers comes in many shapes some with faders, some just with buttons, you can even use a standard midi keyboards that is used for playing music. It just need to be able to generate a midi signal with the correct type of note's.
For FreeStyler the note's send need to be of CC# type. (Control Change)
As alternative software Bome’s midi translator can be used along with others. A google search will be useful to find options.
In general most software that can manipulate midi signals can be used.
Midi-ox setup
More Midi Ox setup See. Midi Ox Setup
Midi and FreeStyler
This means that one button is assigned to select page1 and an other to Page2. By pressing these two buttons the mapping page will change and thereby the functionality of the BCF.
BCF2000
Encoder section
8 x Encoders
8 x build-in buttons
2 x 8 Buttons
Fader Section
8 faders
Button section
4 buttons
Using BCf2000
How to Setup
Start FreeStyler
- Expand External Controls, select Midi Control
- Select Midi Input device
- Select Midi Output device - Optional: used for device feedback (LEDs, Motorized Faders, etc.)
- Click the Start button the midi device
- Click the Learn button
- Scroll down and find the function you would like to assign a MIDI function to.
- Click in the “Note IN” section of the function.
- Using your MIDI controller, push the button or turn the knob that you want to control the selected function.
- Freestyler should be listening for the note and you should see it appear next to the save button.
- Select eventually Page mapping. Here all functions are mapped to Page 2
- Continue assigning MIDI functions to buttons or knobs as you wish.
- Once finished, click “SAVE”.
Page
In all the other page settings the note and the mapped function is only available on the selected page.
Example could be a button that has note 10 with page 1 selected it is “Open Gobo” with page 2 it is “Open Color”, with page 3 selected it is “Open Pan/Tilt and so on.
NOTE: If you configure buttons to set the MIDI page number (or next/previous MIDI page). These should be page independent, or you might not be able to change pages.
Alternatively way if you just wanted to use 2 pages, you could use one page button that in page 1 changes to page 2, and then in page 2 it changes to page 1.
Shift Function
You can configure FreeStyler to use one button on a controller as a shift button, so that when it is held down and another button is pressed, you can respond as if it were a different button.
E.g. you might have a button on your controller mapped to “Fade IN”, but when you hold the shift button and press it, the same button is mapped to “Master 100%”.
Any button on the controller can be configured as the shift function (in this screenshot it's button with MIDI note 19).
Then in order to program FreeStyler to respond to shift + button, you set the page to 6 (see screenshot).
You have to click the “Shift” button on the right side of the assignments and then only press your button on the controller normally (don't press the button programmed as shift or it will get reassigned).
Then when you're finished, change the button in FreeStyler from “Shift” back to Page xx unless you want to program more Shift buttons.
Note monitor
In the screenshots above, the first shows note 101 with a velocity 0 and the second shows note 1, velocity 32.
Here it is a fader that is monitored but if it is a button then the velocity value is to be 127 for FreeStyler to recognized the button press. This can be alternated on most midi devices.
Option
MIDIcon.
This is for the Elation MIDIcon and are to be checked on if the MIDIcon are used. This is checked automatically when a MIDIicon is configured in FreeStyler.
The reason for this option is that the feedback of the MIDIcon is slightly different from other midi controllers.
Import and Export
Disable double trigger protection
This option is related to the MIDIcon controller.
The faders of the MIDIcon tend to stick between two values triggering value -1 and value +1, therefor FreeStyler will only change the value when it detects a +2 or -2 difference.
NoteOn – NoteOff
It is possible to change the default “key down” and “key up” midi command in FreeStyler.
This is due to difference in midi protocol for different controller.
Key Down is default NOTE + VALUE 127 or alternated NOTE ON 127
Key Up is default NOTE + VALUE 0 or alternated NOTE OFF 127
Some of the external command works as flash buttons which means that they have the ON value as long as they are pressed and the OFF value as long as they are not pressed.
With “Convert flash to toggle buttons” this is converted to a toggle which means that the command have the same value until the pressed next time.
Ignore MIDI channel
Some controllers have their own pageing system using midi pages (16 pages), you can disable this behaviour in FreeStyler by enabling this option.
This will allow you to use midi buttons with the same function on every page.
Link MIDI to touch page.
When a touch screen is used in combination with a MIDI control then this function makes it possible to link the page control.
When the MIDI “Page 1” button is pressed then the touch screen shifts to touch page 1.
This can be helpful when buttons are placed on the touch and the related fade are to be mechanical MIDI.
If the link is disabled then the user has to press MIDI page1 and then Touch page 2. This requires that the user always keep the two page control synchronized. If the link is enabled then the PC keeps track on which MIDI page is active and activate the related touch page.
Supported Devices
- Behringer BCR-2000 (Same as BCF2000 but has only rotary control, no faders)
- Behringer FCB-1010
- Akai APC20 & APC40 (change to Abelton mode via Sysex to get button color feedback)
- Akai MPD-16
- Korg Nano Range
- Novation Launchpad
- Novation LaunchControl XL
- Hercules DJ COnsole
- Touch OSC (Midi App for tablets - design your very own layout!)
