Joystick control
The joystick control is enabled by checking “on” the checkbox.
When this is enabled all buttons on the joystick is active.
To control movement the external “Toggle pan/tilt” are be used.
This makes it possible to switch between normal fader control and joystick control.
The joystick buttons are configured in the “Keyboard Shortcuts” where the wanted function is selected and the joystick button to control it is pressed.
“Toggle pan/tilt” can be configured on all external controls, Keyboard shortcuts, touchscreen, midi and so on. See External control.
In the Keyboard shortcuts the Toggle pan/tilt control button can be set to a key or alternative a joystick button. This makes it possible to use a button on the joystick to toggle between normal and joystick control for pan and tilt.
