create_sequence:fx
FX
Ever wanted to create a wave with several fixtures, but never had a good result or spend an afternoon creating it? With this simple sequence creator you can create such effect in a matter of seconds !
1. Select the fixtures you want to include in the wave (order is based on the fixture list)
2. Select the type of wave/effect
3. Select the type of Channel/quality
4. For a wave between fixtures (pan or tilt) you need to check “Distribute fixtures evenly” otherwise all the fixtures will have the same coordinates
5. Click “Generate” to create the sequence
6. Make changes to the scene and fade time
7. Save your sequence
Combine (under a cuelist) several FX sequences to get instant special effects.
FX, Features
Waves/ Effects:
1. Sine
2. Cosine
3. Saw
4. Chase
5. Cascade
6. FlipFlop
7. Inverse Chase
8. in & out
9. Can-Can
10. Special
Channel/quality:
1. Pan
2. Tilt
3. Gobo
4. Gobo Rotation
5. Color
6. Intensity
7. Shutter on/off
8. Iris
9. Prism
10. Prism Rotation
11. Cyan/Red
12. Magenta/Green
13. Yellow/Blue
14. Strobe
These are a lot of features, so I'm not going to explain everything but i will show it with pictures.
And keep in mind you can change everything like you want so there are endless possibilities.
Example 1: Chase - Intensity
This example is made with 12 Par cans with an Intensity (But it doesn't matter what type of fixture it just needs an Intensity Channel).
Low value 0
High Value 100
Per.no of Fixtures 1
Pulse off
Reverse Pulse off
Reverse Direction off
Low value 0
High Value 100
Pulse on
Reverse Pulse off
Low value 0
High Value 100
Pulse on
Reverse Pulse on
Low value 0
High Value 100
Per.no of Fixtures 2
Pulse off
Reverse Pulse off
Example 2: Cascade - Intensity
Low value 0
High Value 100
Pulse off
Reverse Pulse off
Example 3: Flipflop - Intensity
Low value 0
High Value 100
Pulse off
Reverse Pulse off
Example 4: Inverse Chase - Intensity
Low value 0
High Value 100
Pulse off
Reverse Pulse off
create_sequence/fx.1319047020.txt.gz · Last modified: (external edit)
