First time user of FreeStyler.
Is there a recommendation for what fixture to select for a 3 channel DMX RGB floodlight from China ?
Also, is there a fixture for RGB Pixels string ?
I didn't really find an answer while searching.
thanks,
jerry
What fixture to use for a RGB floodlight ?
- FreeStyler Version: 3.6.3
- FreeStyler Version: None
Re: What fixture to use for a RGB floodlight ?
I'd just use a generic 3 channel RGB to find out the channels firstly, then adapt from that if it has more DMX channels. It's the same with RGB pixels string.
Also, don't buy stuff from china if you don't get a manual with it. It makes life difficult. Just a word of advice.
