I have the opportunity to buy this product. It could be used as external interface midi?
Thanks!
Tascam US-2400
- FreeStyler Version: 3.4.8
- lindsayward
- FreeStyler Version: 3.5.5
Re: Tascam US-2400
I don't see why not!
It's a MIDI device and you could set FreeStyler to listen to and respond to its signals.
The only question would be whether FreeStyler supports going the other way - sending data to the Tascam to update the displays and motorized faders...
- FreeStyler Version: Beta
Re: Tascam US-2400
Hej skatejack
If I recall correct then the only thing you are to look at is if it is sending CC nodes.
CC is the only type FreeStyler accepts.
And if I look in the "Native mode Protocol" doc for the Tascam it looks like it is sending CC
There may some setting of the trigger / velocity valuse but that is normally configurable
