Android Server TCP/IP
dmxlighting
FreeStyler Version: beta
Re: Freestyler Ipod touch / Iphone App
Post by dmxlighting »
djSupport wrote:why so serious...? :ugeek:
The king of random comments ? Or did I miss something ?
Re: TCP/IP Server Iphone/Ipad/Ipod/android app
Post by LJ_krede.dk »
check the log,, some posts have been deleted
Android Dev (Moderator)
FreeStyler Version: BETA
Post by Mattotone »
i have been playing with this.
take a look @ http://www.freestylersupport.com/fsforu ... =38&t=2230
If the next version supports Channel commands, then il gladly move my android app over to that.It would be a lot easier for users to have this server built in.
Post by Mattotone »
very good, i will have to dig my iphone out when its released.
can you send me screenshots of each of the screens? il try and replicate the app for android so that we have two matching offical apps.
P.S you need to make a new thread for this...
billhilty
Post by billhilty »
Is there a way to control my cue list? I am able to connect to FS with my EVO, now just trying to control my cues!
MarkT
Post by MarkT »
I have a problem with connecting with ifs server. I'm using freestyler on my mac with parallels.
Just can't seem tot connect from my iphone to the server.
Could anyone help me?
:fs:
cirrus
Post by cirrus »
I don't have a Mac but basically you need to make sure that your windows system running in Parallels will get a real IP address from the WiFi network you connect your Mac to.
Check this article, that might help:
http://stackoverflow.com/questions/2970 ... ost-to-acc
Then open a command prompt in windows, type "ipconfig" to get your windows IP and try to connect to it.
Good luck!
Dominik
Knight
Post by Knight »
I'm trying to understand how the FS TCPIP server works.
Sending de ASCII command FSOC002255 is working ok, it toggles blackout
What are the ASCII commands to send i.e. ch1@DMX200 or ch1-3@DMX128 ?
Can someone please explain that ?
Thanks,
Ed
Post by Mattotone »
your in the wrong topic, this topic is for the external server. and would take your commands exactly as you post above, but each part must be separated by a space.
But to answer your question there is a manual in your fs directory called sendmessages and tcpip.
There is also a topic discussing this exact problem, here http://www.freestylersupport.com/fsforu ... =38&t=2230
matt
Knight
Post by Knight »
I've read the pdf several times :)
Will move over too the other topic, thanks !
Post by Mattotone »
New server version released for use with latest android app.
Also looking for a web developer to create a basic but good looking site for the android app to host all the files required. but also with information on how to use the app. If you can help please let us know.
Vauzelle
FreeStyler Version: 3.3.2
I Use FreeStyler for: Theater
Post by Vauzelle »
I downloaded tcpip server and I am unable to install it on my IBM Thinkpad with Window's XP-pro, it say error code 0xc0000135. What do I do wrong?
Post by Mattotone »
did you extract the thoughtworks.qrcode.dll? this file must be in the same directory as the server.
djlorenz
Post by djlorenz »
hey guy... i found this nice infos for the 1st time...
i have iphone and luminair... i tryed to connect it with the video on youtube but it doesn't work :(
so the only way to control lights is with TCP/IP remote? no news about freestyler iphone app? i can be a beta tester too ;)
Vauzelle
Post by Vauzelle »
I do have the ThoughtWorks.QRCode.dll file wich is in the same directory as the installation server file. Dont know what to do with it.
Post by Mattotone »
you don't do anything with the dll, it something that the server requires access to.
iv re downloaded the rar file and extracted it fine, and ran the server without problems. so that rules out corrupt download.
Ensure you have the latest service pack and .net runtime files installed on your computer. its a long shot but its good to be uptodoate.
ChuckTX
Post by ChuckTX »
I have an HTC Hero running Android 2.1. Whenever I press the quickconnect button on this app it just pops up the market app with this app loaded in the market. Any ideas as to why?
Has anyone tried the $0.99 app on iOS? Zinman one is cool & would get it long term if this setup will function the way I want it to. I hate to spend 20 bucks to try something out.
Thanks, Chuck
Post by Mattotone »
Hi, The quick connect requires barcode scanner installed as explained in the messageBox "To quickConnect barcode scanner is required! would you like to install it! and thats why it takes you to the market,
once installed it will allow you to scan the QR code on the server and auto setup the connection
ChuckTX
Post by ChuckTX »
This function part didn't seem to work well. I was having problems being able to get to the settings menu to try to input the settings manually. When it would take me to the market it was taking me to it was taking me to the remote app page not the barcode scanner page. It never asked me anything about wanting to install the barcode app. This message box finally showed up one time when I did not have mobile internet connection turned on. It seems that it wasn't handling the error of not having the barcode scanner installed correctly.
cocochen
Post by cocochen »
Mattotone wrote:you don't do anything with the dll, it something that the server requires access to.
Reason: Deleted spam links to buy iPad cases
Post by Mattotone »
Please confirm the above post is valid, as it is a duplicate post...if not the entry and user will be removed.
rudykstra
Post by rudykstra »
Vauzelle wrote:I downloaded tcpip server and I am unable to install it on my IBM Thinkpad with Window's XP-pro, it say error code 0xc0000135. What do I do wrong?
I'm having the same issue as described above. And I do have the QRC dll in the same directory as well. Would you have any more suggestions to fix this?
rudykstra
Re: Android Server TCP/IP
Post by rudykstra »
As you described above, I've updated my computer with all possible .net packages (2.0 SP1 & SP2, 3.0 SP1 & SP2, 3.5 SP1, 4) I do not get any error messages anymore, but the server does not start up at all, when I double click the .exe file, now nothing happens at all.
Please help me out on this...
rudykstra
Post by rudykstra »
Fixed the last one as well, in some odd way my computer executed the .exe file with a copatibility mode for win 95. After I unchecked this option, everything is working amasingly well! Great App!!!
vinnygogo
Post by vinnygogo »
hello,
a question. i have a notebook wich runs freestyler with an enttec open dmx dongle. with my android phone an the app, 1 can control it(app is very limited in its possibilities, but its fun:)) now here's my question. i have a dell inspiron duo windows 7 tablet. is there some sort of tcp/ip freestyler version wich i can install on my tablet, enabling me te control freestyler on the laptop en wireless using the tablet? or is there an other solutions for this? i would realy like a solution!
greetings and thanks in advance, vincent
Locked
