Okey.lesjones22 wrote: 04 Dec 2017, 15:15 I have the app running all the time. When I installed your latest release and enabled auto-reconnect, it works by restarting the app. One other issue/question. I'm running it in Guided Access mode so that nobody can go to other apps on the iPad. However, the screen doesn't blank out after the defined time in settings, thus the screen is on 24 hours a day. I'm sure that this will lead to screen burn in. I thought that it may be an issue with the Guided Access mode but I tried it with other apps on Guided Access and it worked fine. Thanks for your help and a great app!
No you are right. Thats implemented in the Code. I stopped the standby-function by default because we use it for events and therefor it was more comfortable. If it is not good for your usecase i will implement a settings-page to disable/enable it.
