UKing 30W Moving Head Light [FIXED] Topic is solved
- FreeStyler Version: 4.1.7
JoPeMUC
Re: UKing 30W Moving Head Light [FIXED]
No inconvenience here. Gave me the opportunity to play a little more with the fixture generator.
Mateo123
I have the 60W version of these moving heads.
Nothing seems to work.
On the moving head display I set A001,A002,A003,A004 (because I have 4 of them).
I set it on 11 channel mode.
Maybe I engaged some other option on moving heads which desrupts it from working properly in freestyler?
OK guys turned out it was the cable that was a bug
ALWAYS CHECK THAT YOUR CABLES ARE WORKING FINE haha learned my lesson
djpopeye
has anyone got file for 9/11 channels as I cant get colours up on mine
dunkyboy
Just to clarify for anyone who is unsure of this. The Sound2Light feature will jump through a SEQUENCE to the beat (there is also a function around pan/tilt to the beat).Rod_Horning wrote: 11 Aug 2018, 05:59 If you are trying to use the Freestyler software sound to light hopefully someone who is familiar can help you. I have not used it and am not familiar with its use.
S2L will not trigger a light that is in sound activated mode, that triggering occurs using the fixture's inbuilt microphone.
You can combine the two, although it's not really recommended.
Kwikstep
Hello,
Is there a pff for a U King 5o Watt Double Sided Mini LEDSpot?
Please post a link to the user manual or upload either a PDF or pictures.
Kwikstep
Thank you for the link. Unfortunately no DMX information is shown or linked to (which is what I always find with eBay links). I sent an email to the manufacturer requesting a PDF of the user manual. They may or may not reply.
I saw the cover of a user manual in one of the photos. Can you take pictures of each page and upload the pictures? Hopefully there will be DMX information that can be used to create a fixture definition.
U'King provided a partial user manual. Based on the information provided by U'King I created the attached 21 channel fixture for your instrument.
Your feedback is welcome.
Also attached is the PDF of the user manual provided by U'King
Note that, according to the manual, your instrument has 2 sets of RGBW LEDs. The attached fixture uses Freestyler's RGB segments. If you open the Colors window you will see, in the lower left corner, 2 check boxes. Freestyler will send DMX values only to the set(s) of LEDs that are checked.
U-King 50W Double Sides Stage Lighting RGBW LED Beam Moving Head DMX512 DJ Light.pdf- (233.7 KiB) Downloaded 79 times
UKing 50W LED mover 21ch.pff- (6.15 KiB) Downloaded 78 times
Jaime
boa tarde senhores alguem consegue uma fixture em anexos tb sou novo aqui ficaria grato obrigado estou tentando as acima mais nao estao batendo os canais antecipadamente agradeço
