FreeStyler X2 and uDMX - Setting up second universe
gferrero
FreeStyler Version: 3.6.3
Re: FreeStyler X2 and uDMX - Setting up second universe
Post by gferrero »
Some days ago Lutz from http://www.illutzminator.de sent me and e-mail with an improvement in uDMXArtnet for making it work with two dongles in the same computer, even when they have the same serial. I copy the Lutz message:
I built a new solution: uDMXArtnet got a new parameter -n <number of device>
So with
uDMXArtnet -n 1
you use the first available uDMX and with
uDMXArtnet -n 2
you use the second one.
Using serial number is more secure as unplugging and plugging again will always definitely find the same device, but in most cases
uDMXArtnet -n <number of device>
should also work as long as you always use the same usb-ports.
This is only implemented in uDMXArtnet not in uDMXCapture.
New uDMXArtNet can be downloaded from http://www.illutzminator.de/udmx-artnet.html?&L=1
pisach
Just started using FS
Post by pisach »
I see, so if it has a bootloader it won't need programmer! OK, but again the VID/PID...
Code: Select all
 trying to connect to device...
avrdude: error: could not find USB device "USBasp" with vid=0x16c0 pid=0x5dc
I guess nothing can be done here :evil:
pisach
Post by pisach »
I will look for other Chinese "solution", I'm sure there is!
pisach
Post by pisach »
OK, the other solution is with FTDI chip. Here is described how it works. The only obstacle here is to find genuine FTDI chip. The boards with clones work as USB to RS485 converters, but cannot be programmed and that's why are not suitable for DMX.
Here is one very good how-to: http://stevenbreuls.com/2013/05/diy-usb ... -under-10/
I have to find what is the difference between uDMX and openDMX......and why do I need uDMX, when the both cables work with FreeStyler?
gferrero
Post by gferrero »
uDMX, openDMX and so are not standards, just different drivers associated to each USB to DMX interface. I've reading your previous posts and it's not clear what do you need exactly of what is the problem you're facing. Most dongles work great with FreeStyler.
pisach
Post by pisach »
I just wanted to install on it the firmware from http://www.illutzminator.de and to make it work with the DMX software from there, but now I think it's not possible.
Thanks!
gferrero
Post by gferrero »
So, you can not configure your "supposely" uDMX dongle with FreeStyler right now and make it work? If it works with FreeStyler, why do you want change the firmware?
pisach
Post by pisach »
...I don't know, to make it uDMX, or just to "hack" it, now I'm not sure :-)
ok, at least I learned some things, thank you!
buttza
FreeStyler Version: 3.6.4
Twitter: twitter.com/@buttza
Post by buttza »
Wow. I have to admire your tenacity. :)
