Chauvet Radius 2.0 Profile?
spud1511
FreeStyler Version: 3.5.7
Re: Chauvet Radius 2.0 Profile?
Post by spud1511 »
That's why I put the final tested lasers there in user created fixtures section. Hope that was right thing to do.
I only made one for chauvet radius 2.0 (with graphics, etc) so there was no updated or final version as from the one marked as draft/untested reportedly worked perfectly off the bat without issue so I never needed to change anything. That's why I wasn't sure as that one was technically already uploaded. Plus I wasn't sure whether you did finish/test a better one? Or stopped working on it after the issues? (Not sure anyone would blame you)
my versions are attached to my post further up
spud1511
Post by spud1511 »
I don't imagine there's gunna be a massive difference either way, mine was confirmed working. But I would also bet on yours working perfectly too since your more experienced than I am at this fixture lark! Though when I get back to my pc I may just take a look see in case you did anything different (for my own learning).
I didn't use the P/T way you mentioned because I'd have to explain that and I know from experience if they cant build profiles they wont get that so I use macros just to raise the sliders up and down in increments,,,
Post by Jan_K »
Hej folks
Just for the fun of it and to say that more complex fixtures time increase dramatically then I have made one of the laser fixtures.
I have used round 10 hours.
Entering values and figuring out what controls I want to have where and so on takes time but creating new icons and patterns that is a killer. (I was lucky to find most of the patterns)
To support "djSupport". It takes time even just to enter the dmx values. It may look like a lousy fixture if the images are not correct but I don't think anyone will pay for 10 - 20 hours work just to get patterns correct.
And to inspire you two have a look on my solution for the laser.
KAM_Laser_XY_RGY_10ch.pff
(201.65 KiB) Downloaded 26 times
since doing the paid fixture service i've amassed 1170 custom image labels!
and yes jan, it takes hours and thats what i'm charging for...
Post by Jan_K »
Takes forever. :D
Just to say you have worked for your money.
Locked
