Generic Chinese LED "Crystal" Mirror Ball
max.schollen
FreeStyler Version: 3.4.6
Re: Generic Chinese LED "Crystal" Mirror Ball
Post by max.schollen »
Spirit wrote: 14 Sep 2013, 10:55 hi you can also try this fixture file they seem the same but i added a little bit more Macro's
After download and install i get the error code
Please fill in all gobo values
Post by Jan_K »
Try this one.
It is the same file just saved / exported with the latest version of Fixture Creator.
unknown_magic_ball_06ch.pff
(30.71 KiB) Downloaded 114 times
max.schollen
Jan_K wrote: 03 Aug 2017, 06:05 Try this one.
the Colors are not good working
And rotating is not working !
Post by Jan_K »
Is it exactly the same fixture you have and does it have the same DMX table.
Eventually upload the dmx table here so we can check.
max.schollen
The thabel
Post by Jan_K »
The colors looks okay but the motor control don't match the DMX table 100% so you need to create your own.
If you look at channel 5 then in the table then there are 3 functionality ranges and in the fixture file only two are defined.
max.schollen
Jan_K wrote: 07 Aug 2017, 06:12 The colors looks okay but the motor control don't match the DMX table 100% so you need to create your own.
how can I do that ?
Post by Jan_K »
Well you open the fixture with "Fixture Creator" and alternate the functionality for channel 5.
It is made as a gobo1 control.
(Save the fixture with a new name so you have the old as backup)
You had and issue with color "not good working" please explain?
Return to “Generic”
