REVO IV
lowi85
Re: REVO IV
hello
I repeat and renew the question - how do you guys get the Revo back to sound active as it's in 256ch mode??
It's possible without disabling the freestyler?
- Spirit
- FreeStyler Version: 3.5.9
Re: REVO IV
I have taken a Quick took at the PDF But this is not possible with 256 Channel Mode.
the only thing i can come up with is.
Patch 64x a RGBW Fixture and enable sound to light on Freestyler.
or you can also use DMX400 with Sound to light.
nicovj
Re: REVO IV
Hello DJ's
I'm new here, just bought one ADJ Revo 4, including a USB Entec DMX controller.
I've installed Freestyler 3.5 and the fixture for Revo4 and everything is responding fine using faders, although, I'm trying to follow the tips and hints here around writing texts using Suntrix and my Revo is not responding to it.
Basically it seems to enable sound mode when I enable the Suntrix output. Looking to the master view, the 4 channels was turned to 255, which explains it.
Any suggestion about what I'm missing to make it work and respond with Suntrix (or ledtrix)??
Thanks Everybody!
Vinicius (NicoVJ)
Thanks Everybody!
Vinicius (NicoVJ)
- Spirit
Re: REVO IV
hi
i dont own the Revo so i'm not sure..
but you dont need the 4 Channel MODE but the 256 or 512 channel mode this way you can control each LED on a Differnt channel.
and then FS control write tekst on it..
potents
- Just started using FS
- FreeStyler Version: 3.5.2
Re: REVO IV
Max can you help. Do I have to enter all 256 values manually. How do I do this for universe 2. Can anyone help? Thanks pete
- FreeStyler Version: Beta
Re: REVO IV
I think you can only do it for universe 1.
And there are a auto address so you don't have to enter the channel manually.
http://www.freestylersupport.com/wiki/f ... s:ledtrix1
potents
Re: REVO IV
OK for me there are not 256 addresses free in a block in universe 1. How do I move fixtures to lower addresses to create 256 free addresses in universe 1 without loosing the programmed shows associated with the fixtures.
Best way i can describe problem is i need to defrag my universe 1 to create 256 free addresses. Thanks pete
Re: REVO IV
I had that problem at a time and the only solution for me was to use a second pc with an usb-dmx dongle which only controlled the ledtrix.
djmario
- FreeStyler Version: 3.6.6
Re: REVO IV
Hi, i got show tonight is there any chance to get fixture file or some explanation (im begginer in FS i know stuff but not that hard) for Revo... Thank you
