TCP Server Client C#
Android Dev (Moderator)
FreeStyler Version: BETA
Re: TCP Server Client C#
Post by Mattotone »
never used but imagine it increments the gobo channel value by one ie. 1,2,3,4,5,6 ... 255
where as next gobo selects the next gobo in the fixtures list
Post by Mattotone »
well max byte is 255.
i imagine it will be {70,83,79,68,255,49,0 to 255,0,0}
Knight
Post by Knight »
Mmax, did you already find out how to send 1@dmx255 or simulair ?
When i see your code i don't understand how you define 1 click.
The table says command 1 = 320
So i guess it has to be:
{70,83,79,68,320,0,255,0,0) // 1 click
{70,83,79,68,320,0,0,0,0) // 1 release
@Mattotone - can you please help me/us out.
Lot off commands do work, but only single line commands like ' select next fixture = 288' or 'Master 100% = 151'.
Still i can't get the commands to work that sends values to channels.
When i open the command line feature in, and i sent i.e command 1, can i actually see the number in the command line ? So does the command line tool get filled with all the commands we send until we cleat it ?
Because i don't see anything happen, but when i set master 100% i see it pop up.
Knight
Post by Knight »
ah clear, missed the 'split up' part.
Fog level does work. When i send FSOC304100 it sets the level to 39%.
Knight
Post by Knight »
It;s the same table you use for byte protocol except there is no need to recalculate.
For example blackout = 002 then you send FSOC002255 (where 255 is click)
In the table it says: Fog level 304 0 to 255 this makes: FSOC304xxx (where xxx= 0-255).
jg5985
FreeStyler Version: 3.0.1
Post by jg5985 »
How do you tell freestyler your disconnecting and close the connection?
If i close then reopen my sending application the connection )or close and reopen the socket) the connect is refused by freestyler unless i click the disconnect all button first within freestyler.
jg5985
Post by jg5985 »
never mind solved the issue just added the following before terminating the executable.
clientStream.Close();
client.Close();
youngkwangk
Post by youngkwangk »
Hello I have a question.
I understand that you should split codes greater than 255, but how would you do codes greater than 510.
For example, 595 - submaster list change 1 ?
Post by Mattotone »
dont think it is reachable.
Mitologico
Post by Mitologico »
Hello!
How can i read the caption of override buttons using c#?
Thaks!
Mitologico
Solved! I used StreamReader object!
Mitologico
In the next relaese can you implement a code for request the override button tab caption? i'm working for a web GUI using jquery and php
MDAR
Post by MDAR »
Hi
Just a quick question...
Can someone tell me where i can find the list of TCP/IP command codes.
I've been searching for an hour and can't locate them..
Thanks in advance.
Stuart
Now I feel like a fool...
There was I looking on the website and forums, it never occured to me to look on my own harddrive....
"Full documentation for this and the send message protocol can be found in your FS instalation directory"
superdiy
FreeStyler Version: 3.5.5
Post by superdiy »
Hi
I managed to send commands oven TCP/IP using the ASCII and Byte methods, but when I try to read something using the byte protocol, I don't get any response from FreeStyler.
I also think there is a typo in the documentation - it refers to byte 9, but when your protocol only have 9 bytes it goes from byte 0 to byte 8 only. So I'm not sure if it should be 10 bytes instead, but I tried sending 9 bytes and 10 bytes without any luck.
Byte Protocol: 9 bytes
byte 0: “F”
byte 1: “S”
byte 2: “B”
byte 3: “C”
byte 4,5 and 6 : Code (see table)
byte 7,8 and 9 : 0
I'm using Delphi and indy idTCPClient component - as mentioned the send commands do work, but the "request byte commands" do not return anything.
...currently testing locally to 127.0.0.1 and port 3332
Usage example to query FreeStyler version (command 010)
TCPClient.IOHandler.Write(BCmd); //The value for BCmd which is sent to Freestyler is: (70, 83, 66, 67, 0, 1, 0, 0, 0)
Resp := TCPClient.IOHandler.ReadLn('', 5000, -1, IndyTextEncoding_UTF8);
Memo1.Lines.Add(Resp);
Any help will be appreciated.
Thank you
