GO Monkey - Theater / Band Cue Stack
Discuss Go Monkey here!
edoerfel
Re: GO Monkey - Theater / Band Cue Stack
Post by edoerfel »
Hey Mattotone,
any news on a Gomonkey 2?
i heard some things about it but its been a couple months?
I'm sure we could get a decent donation racked up for it as a lot of people would use it!
hypnomann1
FreeStyler Version: 3.6.1
Post by hypnomann1 »
Love the idea of Go Monkey..downloaded the Rar file...I'm brain dead and can't figure where to install it
lobelzar
FreeStyler Version: 3.45
I Use FreeStyler for: Theater
Post by lobelzar »
bonjour, ou trouver un tuto pour go monkey? merci
mousegr8house
Post by mousegr8house »
how to setup go monkey:
install go monkey in the c:\Freestyler folder.
put all sequences (.chb files) made with freestyler in : c:\Freestyler\chases
make xml file with go monkey like in this video https://www.youtube.com/watch?v=O-yoWQyBJfk
save xml file in c:\freestyler folder.
run freestyler
next run go monkey , the xml file is already loaded by default.
if you see a xml file SL , its from the sound 2 light app SL located in c:\freestyler
delete the xml file and the exe , from the sound 2 light application
now it should work
Kenny
FreeStyler Version: 3.6.4
Post by Kenny »
Hi Guys
I am very new to all of this, and have zero knowledge when it comes to .xml files
My first problem I have is getting Go monkey installed the correct way
I have downloaded the latest file and installed this using the default path
When searching the forum I see comments like this must be installed in the same Directory as Freestyler
However I do not seem to find and Installation and setup Manual for Dummys
So I can follow simple instuctions
There is also a mention in the forum of a drag and drop function to drag the cue into go monkey But I don't see this when I open The go monkey interface
All Help will be appriciated
Regards
Kenny
Android Dev (Moderator)
FreeStyler Version: BETA
Post by Mattotone »
Files should be installed in your main freestyler directory. I believe c:/Freestyler is the default.
To Create shows and Scenes, in the top right there is a button labeled edit / create cue stack, this will open the XML editor.
Return to “GO Monkey - Theater / Band Cue Stack”
